BoatingTimbo
- Joined
- May 18, 2009
- 78
Ooops! Thought i was topping up the outdrive oil reservoir (for my '97 Bravo II) but it was the power trim motor reservoir!!
So now the power trip motor is a mixture of ATF and Quicksilver high performance leg oil. Is that going to cause a problem with the power trim pump? If so is there a way to drain the reservoir to replace the fluid?
What is the correct fluid for the power trim pump?
