You may have read in another thread that I am dealing with a thruhull fitting (livewell drain) that was letting water into the transom. I luckily caught it early enough to where there is no rot (except for a very small amount on the surface inner skin). The core wood is solid, hard and splintery yellow but it is pretty damp. I am going to let it get good and dry before I seal up the soft spot and re-do the thruhull. Seems like I have read somewhere that you can use acetone to speed up the drying process for wet wood. The mounting hole is approx 1" 1-1/4" Any thoughts, info opinions, methods for this? Normally I would just leave it alone but with it turning colder I figured I might want to give it a littl help.
Thanks
Thanks
