adaptor plate,why did thay make the exhaust dump..
dzoolk
adaptor plate,why did thay make the small opening seperate from the exhaust pipe exhaust dump..into the midsection on a 1975,135,rude,, it dumps burt carbon onto the waterpump and ooozes black splooge out the drain holes all over the outside lower unit cavitation fins..is it for cooling? dam! i could have blocked that off and made extra water flow in there some where else.thanks all.. anyidea why?
Joe Reeves
Re: adaptor plate,why did thay make the exhaust dump..
That sounds like you neglected to install the inner exhaust tube extension housing. With that extension missing, the exhaust can blast right at the water pump and cause the problem you describe.
dzoolk
heres a pic of the passage
see what i mean? what is the purpose of the extra hole? it flows exhaust seprate from teh exhaust pipe.rt into the midcase! is this where the 2 holes onback of engine midcase spray out the exhaust when the engine is at idle speed to relieve back pressure?.why dont newr engines ooze black splooge?http://i39.photobucket.com/albums/e189/dzoolk/exhaustpassge.jpg
