Jarcher3
- Joined
- May 9, 2016
- 113
I know its been covered but after searching for a while i cant really get the details im lost on from the other threads....
01 Larson 4.3GL 65A alt. (figuring to use the 120A kit still) i have two batteries Starting and DC with a two bank charger and i want to add a blue sea systems switch and ACR.
while looking at the diagrams I'm not seeing much on actual wiring, just the diagrams that don't help to understand it fully.
so for the starting battery i connect battery>switch>starter that one i see and makes sense..
for the house i connect Battery> switch> what? is there one main wire that runs to my fuse block? what about the yellow radio wire and the bilge? are these connected somewhere else on the engine?
Do i link the batteries negative as i have seen, or buss bar? currently they are both grounded on the engine.. would that work okay?
What type of fuses should i use on here? im looking at the AMI/ MIDI, are MAXI better worse or just a different type. are circuit breakers worth the extra 20$ per?
would my 2bank charger work the same still?
can i move my battery to the opposite side for Weight Dist? just use the proper cable sizes and be fine? is there any radio interference issues with running these along other wires or should i run them separate?
overall i understand the kit but the details are what is getting me.
Thanks in advance..
Thanks in advance..
