Add Transom Bench
lmannyr
I'd like to add a bench seat to the transome facing the bow. I don't want to loose the storage. So i was thinking of a bench similar to this, except 52-58".
From starboard to the port transom door is ~63". Now, I need some ideas/suggestions on how to install it not to loose storage and still be able to open the engine hatch.
I was thinking using a SS piano hinge across the back rest of the bench screwed into the forward facing face of the transom. This would hide the screws behind the seat and can flip the seat up to get access to the storage areas. Also adding support legs on each corner to support the weight when in use.
Will this work? Will it last? Does anyone have a better idea? I'm open to suggestions as this is in the VERY EARLY stages of planning.
Manny
