Re: Add water pressure gauge to 1970 115
I used the 30psi kit too. I didn't have to tap the plug hole, but I did end up drilling it out and using an extractor (easy-out) to remove it. Then the brass fitting screws right in. The Teleflex pressure guages come with about 6 different fittings that work on most model engines, hose, tie-wraps, and instructions. If you think it will take more than about 14 feet of hose, buy the hose extension kit too. Basically another length of hose and connector.<br /><br />If there is no plug, then the instructions say to drill and tap, or connect to a water hose. <br /><br />Check out my other post tonight about how I almost pulled the gear case thinking the pump was shot. Bottom line is don't expect a pressure guage to register if the motor is on the hose and not in the water.
