feel free to move if in the wrong section........
for osme od reason my boat does not drain water properly. the stringer right below the front motor mount is solid and water can not pass through to the bilge pumpor the bilge drain. after a rain i have to put a spait bilge pump infront of that stringer to pump the extra water out and let it drain out the back of the boat (boat sits on trailer for right now). To fix this issue and not have to worrie about it again i am going to mount a bilge bump with float switch in front of this stringer. i want to run a hose to a thru hull connection to pump that water right out (like the main bilge pump). now for the question
The thru hull i have sys 3/4 in on it. i am assuming that is for the hose connection and i i measured the inside of the plastic nut and it was a little bigger then 1 inch. would a 1 inch drill bit work for this?
what kind of precautions should i take before drilling into the jell coat/fiberglass on the transome?
will any ol bit work? what about using a butterfly bit?
after hole is drilled should i put 5200 around it to seal it back off?
any other thought or concerns would ber greatly appreciated and many thanks
