yorab
Ensign
- Joined
- Jul 6, 2002
- 960
Haven't found anything on this topic--probably because I don't know the correct terms to search for...
I have a portable tank in my fiberglass tri-hull that is about 16 gallons. It fits nicely up under the splash well. When I need to fill up, I slide it out, fill 'er up, then slide 'er back. It's a bit inconvenient and the risk of spilling gas or oil in the boat is more than minor. I'm wondering if I could run a hose up from the tank and connect it to a thru-hull gas filler cap around the splash well area. That way, the tank can stay under the splash well and gas or oil would only end up on the outside of the hull in the case of a spill.
Is this possible/safe?
