I have acquired a new ( to me) '87 24-footer with a 115 merc. It came with 4 - 6 gal. original tanks. But it?s a pain, when you run out of gas, opening the back seats up, swapping the fuel line, re-prime, and hope it starts again. Also, running out when in a narrow channel is not fun. There is no fuel gauge, which I want to add.
I noticed others with older 'toons had placed larger above deck tanks on the back over a pontoon. So I went and ordered the Moeller 20 gal above deck tank and straps. But when I called the place I ordered it from, they told me I can't put a fuel sender unit in it, and have to use the gauge on the fuel cap. I wanted to add a gauge on the console, so I don?t run out of fuel.
For those with older ?toons, has anyone added a sender unit, how difficult would cutting into the tank be?, or do most people with older 'toons just look over the back at the gauge on the tank? and hope you don?t run out of fuel?
Any suggestions would be appreciated.
Warning: I will be having more questions as I use this thing more ;-)
thanks,
Chris
thanks,
Chris
