dOb
- Joined
- Jun 14, 2010
- 244
I have a 1979 Johnson 85 hp Seahorse. I?m in the process of rebuilding the boat that it lives on. I?ll be adding a Tachometer to the instrument panel.
Question: when I wire in the new tachometer (an after market marine tach) can I just set the pulse switch and wire it in and I?m good to go? The reason I ask is that my last motor was a 1974 Mercury and in order to get a new tachometer to work, I had to cut into the wiring harness at the motor end and reroute some wires (to the rectifier I believe). Will this be the same situation or will the new tach work on this old motor?
Thanks.
Thanks.
