Adding a tach
firedawg662
I'm new to boating and have learned alot in this forum, but I can't find the info I'm looking for about installing a tach. I have a 1985 Bayliner 1710 Trophy Bass Boat (I think) with the same year 85hp Force motor. My question is can I use an automotive tach since there is a tach lead on the electrical block on the engine? The unit I bought says its not for marine use, but isn't a 12 volt system a 12 volt system? I need the tach since I put a larger prop with 2 degrees less pitch and do not want to over rev the motor.
NYBo
Re: Adding a tach
It won't work, at least not properly. You need a tach that works with a 20-pole stator, which is getting hard to find. I don't know if anyone still makes them. I had to score a used one off eBay for my boat.
Jiggz
Re: Adding a tach
Tachs are rated not only in voltage but also in the number of poles from the signal source. In this case you will need a 20 pole tach. Of course, there is always those magnetic signal tachs or pulse tachs like tiny tach.
Jiggz
Re: Adding a tach
20 Pole tachs are getting harder to come by with each passing year
