onehunglow
- Joined
- Jun 9, 2004
- 61
I have a 1987 Evinrude 70hp with a standard Temperature SWITCH. I had a strange horn problem last year (where the warning horn goes off steady even right after starting the engine yet nothing seems wrong - water, heat, oil, etc - turns out a faulty oil pickup sensor). I want to install a temperature gauge so that I can see whats going on in case something like that happens again.<br /><br />I see mixed information on this - Teleflex says you can either screw in a sensor or mount it on a Z-bracket. <br /><br />Is one method better than the other? I don't want to replace the switch since it will alarm if I am not watching the gauage. If I install with Z bracket, I assume I have to use a head bolt <br />(Uggggggh - the thought of undoing a head bolt in a perfectly good running engine scares me) - and then doesn't it have to be re-torqued back?)
