I have a Mercruiser 3.0LX engine and an Alpha One Gen II sterndrive and I would like to add an after market fuel/water separator similar to this one:
http://www.sterndrive.info/sterndriveparts/id1.html
We are trying to decide whether to install it in the back of the boat, near where you add oils and other fluids, but quite aways further back and above the fuel pump. Or would it be better to mount it to the side of the engine housing at a point lower than the fuel pump? There's already a half inch thick piece of wood alongside the edge of the engine housing that has hose clips attached to it already. Easier to maintain it from the rear storage compartment but not so bad in the engine housing either.
Kind of a related question would be on a 1997 Maxum is it possible that a couple of inched of floorboard would come up so that I can get to the hose fitting for the gas tank. If we decide to run it clear to the back it would be nice if I could easily replace that 3/8" piece of tubing that carries the fuel to the fuel pump.
TIA for any advice you can offer...
