This is a 1967 MerCruiser 120 in a Astro Marine Starflite 18. While performing the first running after having the original head rebuilt I noticed a lot of movement from the front mounting point before I got the idle adjusted. This obviously an older boat but it is in great shape. But the floor of the engine compartment was flexing more then I liked and some small cracked in the paint on the floor have started, that likely has allowed water(from skiers/boarders) that would normally stay in the engine compartment and be pumped out by the bilge, to get into the lower hull area. I did notice last year when draining after several days on the lake that the lower hull had been holding more water then is good. I have plans in the next year or two to pull up the floor to add reinforceing and foam so that the old girl won't be killed by all the stupid huge wake board boat wakes out there.
So I fabed up a couple of bracket to mount on the original GM mototr mount holes to take some of the twist out of the engine. What do you think. They will be bolted to the floor, just had not yet drilled and painted(Phantom Black of course) the brackets when I took the pics.
