Re: Adding extra fuel tanks
We just did a 200-gal fuel system re-design for our boat. I am presuming you want a permanent fuel tank installation. Here are a couple things I learned that might help.<br /><br />1- ALL fuel tanks are required to drain from the top with a metal fitting. No way for a crossover to function, as it would have to drain low on the side or bottom to do so. The reason is fuel line is flexible and easily compromised. Any rupture in the line and fuel is pouring, gravity fed, into your boat. Any onboard fire, the line is the first thing to burn thru and the fire is quickly being gravity fed with fuel.<br /><br />2- All of the weight in your boat wants to be centered and low. Obviously, it isnt, like the engine in the stern, but keep working with this in mind. Stability is NOT achieved by even distribution of weight. It is achieved by keeping it centered and low. Adding 50-gal of fuel is adding 400+ lbs of weight. It will make a huge difference in the stability and ride of your vessel. Getting the extra weight where it needs to be will make you much happier.<br /><br />Is there any way at all that you can get an aux tank somewhere down in the center of the boat? Custom-made aluminum tanks are a one-time expense and probably not as expensive as you think. If you go this route, you will want to have the tank built by someone that does marine fuel tanks, specifically. There are some other technical issues required by the USCG that they will know about and incorporate into the tank. They also understand the needs for internal baffling.<br /><br />3- Multiple tanks means fuel use between the tanks cannot be even due to the motion of the ocean. As soon as there is significant consumption from one of the tanks, you will start to list and continue to run alist until all tanks are either emptied or filled. Fuel is not going to run up-hill into the tank with the least fuel in it. This being the other reason crossovers dont work. It will guarantee one of the two aux tanks is kept full until the other is empty.
