I have a 2005 Bayliner 175BR. I've started adding a few accessories (depth sounder, stereo, etc) and was originally thinking that I should maybe add a second 'switched' fuse panel that only works when the ignition is on. Then I was thinking that it would probably be better to actually wire the accessories to each of their own switches. Does anybody have a similar boat that has done this sort of thing? What sort of switches/panel did you use? Where did you mount it? Any other tricks, tips or suggestions?
I'm sure I won't need more than a few switches. I was thinking I might eventually add some LED lighting.
Any suggestions?
Thanks.
Any suggestions?
Thanks.
