Re: Adding on board charger - help/advice
Thanks for the input – Since the boat is in a slip, I’m still worried about the galvanic isolation though. Would the charger have that built in (I guess they would document if it was) or would the dock power outlet have it built in there?
All the outputs on a reasonable multibank charger are isolated from each other and from common ground. If the boat is "galvanically" correct, a properly installed charger shouldn't change anything.
If it's in water, just be sure the shore power is GFI protected, to insure safety if something goes wrong.
Just to clarify, the battery isolation is in the design of the charger. A GFI protector compares the current going out the hot wire with the current coming back on the neutral wire, and if they differ by enough current to hurt you, typically less than .010 amp, it will trip. The assumption is that the missing current is going to ground by some other path, possibly you.
hope it helps
John
