Adding Power Tilt and Trim
SSCVFD
I have a 1979 Thundercraft 16ft bassboat, with a 1967 Mercury 065, thinking about adding a CMC PT-130 kit, what would be my advantages and is there other opinions for a power tilt and trim unit?
roscoe
Re: Adding Power Tilt and Trim
1 - It will save your back from injury.<br />2 - You can trim motor in for a better holeshot.<br />3 - You can trim the motor out to get your boat fully up on plane for higher speed and less strain on the engine.<br />4 - Easier and safer operation in shallow waters, and launching and loading.<br /><br /><br />Panther makes a comparable t/t unit.<br /> http://www.iboats.com/mall/index.cgi?prod_id=37931
cuzner
DO IT !!!!!!!!.Haven't used manual tilt in years,The only thing worse than that is having a dead battery and using the pull start.<br /><br /> Jim
