Adding power trim ?
Bunky
what is needed to add a factory power trim unit to a non power unit outboard ??
My cousin has a non power trim 850 merc. and I came across a 850 merc the same year with a Factory power trim unit what is entailed to put this on the other motor ??
Chris1956
Re: Adding power trim ?
Bunky, We will need the year of the motors to know what PTT unit it has. The early ones had bolt on trim cylinders and the pump mounted in the boat. They were simple to install.
1976SRV190
Unbolt motor off power tilt trim unit, unbolt the manual motor from it's manual unit, bolt the motor you want on the power tilt and trim unit, go boating with a smile on your face! I even did a 1964 4cyl Merc 650, onto a 1974 Merc 650 three mount and it bolted right up so I had a 1964 Merc 650 4cyl with power tilt and trim! And a manual POS 3 cyl 1974 Merc 650 which I sold......quick.
Bunky
both the Motors Are 1974 850 Mercury's
From what I can tell you just remove the stabilizers (shocks) and mount on the power trim, But we questioned if the Clamp units were the same on the power trim and a non power trim...
what do you do about the Locking mechanism on the non PT unit and the strap with they also just swap out ??
1976SRV190
OK, the motors are identical, so if you simply unbolt the non power tilt one from the main mount, then bolt it to the power tilt main mount it will be a power tilt trim unit. The removal of the power tilt actuators is not necessary and is more work.
Chris1956
Bunky, You need to remove the shocks from the manual tilt motor. Now bolt on the PTT brackets on the upper shock mount. Now bolt the PTT cylinders and hoses to the bracket and lower shock mount. Install the pump and resvoir in the boat, and route the hoses thru the splashjwell and connect to the pump. Now bleed the unit.
