Adding Temp Gauge to Johnson 140
O'Connor
Anyone know if there is a place to install a temp sender on a Johnson 140?
I'm not sure what year it is but it appears nearly identical to my '77 Evinrude 115 except for a few things like coil location etc.
emdsapmgr
Re: Adding Temp Gauge to Johnson 140
Get a teleflex gauge and a teleflex sender that are compatible with each other. You can fabricate a bracket for the sender. The bracket can mount under one of the bolts on the head cover and hold the tip of the sender to the face of the head.
