Re: Adding Tilt/Trim to 1965 Sea King 50 hp Outboard (Chrysler)
This motor has not been started in a long time. Where do I start?
1. Make sure the flywheel rotates. See #4.
2. Pull the plugs and inspect them. In my [limited] experience I've found that 'bottom' plugs are more prone to show fouling than 'top' plugs.
3. Got plug fouling? Pull the head(s) and check head gaskets.
4. Squirt a bit of fuel mix into each cylinder, then give it a few hand cranks. ITEM: Bend up some copper wire that will hold when inserted into the spark plug boots, and ground those wires. The object is to inhibit sparking and starting a fire.
5. Check each cylinder for ignition to its respective plug. PROTIP: Get an 18" length of solid copper wire and solder on a cheap battery clamp at each end. With that tool you can bend the wire and position the plug away from the head and in a place where you can see if you get spark.
Cheap battery clamp
6. ASSUME the points are dirty and possibly mis-set.
7. Which leads to a wheel puller:
Wheel puller
