I have an 89 Evinrude 40hp with an aftermarket power tilt/trim on a 72 Ouachita boat.
I just purchased a 92 tracker tx-17 with an identical engine other than the engine is also a 1992. I want to take the tilt trim off the 89 and put in on the 92. I don't think i'll run into too much trouble other than:
The Tracker has a tilt trim swith on the throttle (yeah!) and at the bow near the plug for the trolling motor. The question I have is where is the wiring for the switches located? Do all those wires meet at the fuse box?
The Ouachita tilt trim switches are just toggle switches that I prefer not to move to the Tracker, since it already has all the switches installed, I just don't know where the wires come together.
On another post, I found a number for Tracker Customer Relations, and when I called it, the recording said "All Representatives are on the phone assisting other dealers" so I hung up not knowing if they would work with a consumer or not. I didn't want to rack up too many cell phone minutes.
Thank you for any help you can give.
Brian
Brian
