additional pump
alpolo
This may sound not right, by my question is: is it possible to add an additiona fresh water pump? I have an AQ125A (Volvo) and it has tendency to overheat sometimes. I tried many things, but I am not sure if they work (getting annoyed by this). I was thinking what are the chances to install an additional pump, let say electric, that would "supplement" an original "impeller" pump and would be turned on when needed? Please comment, but don't laugh too hard, it hurts :)
tommays
Re: additional pump
if your orginal pumps are working corectly the motor will run at the correct temp. if your motor has something wrong that wont allow the water to flow all the pumps in the world wont help.<br />the last thing that happened to me was that after sucking up some great south bay bottom some small stones started to block the stat and over time they alowed more and more thinks to cut down on the water flow till the engine started to run hot after cleaning evering out back to normal.you just need to go through things carefuly and try to find anything blocking the water flow<br /><br />tommays
f_inscreenname
Re: additional pump
Don't cure a symptom find the cause. If you pump is not pumping enough water now adding another one will not help much. Only so much water can go through a block at one time. If you have some sort of restriction in the motor or exhaust manifolds (my guess) all the water from a second pump will just go out the exhaust over flow never cooling the motor.
wally jr
Re: additional pump
a bandaid will not cure the problem. senoir chief is right. with a volvo your on a fact finding mission..there are a couple posts in here with the same problem regarding volvo 125's. i have the same motor and have banged my head literally trying to figure out whats wrong sometimes. inlet screens, impellers,sea water strainer,maniflods clogged? when was the last inspection of all water flow? do you overheat underway? before wot? give us some symptoms...
alpolo
Re: additional pump
Thanks for the comments. I just replaced manifold, head gasket, little polishing on lifters, all loose ends, etc. Actually all this for 20 year old boat is not that bad, considering it is being done for the first time. I am a third owner of this boat and have it foe past 4 years. Besides occasional overheating i have not had any problems. Overheating was sporadic, mostly associated with rough water and speed. When water is calm, it will not overheat. I took boat on Lake Michigan, and while there were no waves I had no problem (going to the fishing spot, full throttle for about 7 miles). Later however, winds changed and on the way back we were jumping on 3 foot waves, and start overheating. Had to go medium speed, so the whole stern was under water. I know that some seals/washers in the upper parts of the stern drive are worn off and need to be replaced. I have placed muffs on the water intake, taped them real good and turn water on. Water start pouring from the junction where the seal is, right below the goose neck where rubber pipe is connected. I have changed water line that is inside the boat, by the engine, that goes into the pump. I have removed copper pipe and replaced that with the same diameter rubber, steel reinforced hose. I was thinking that by adding some other means of supplying water I may help little bit, but judging from your comments it does not make much sense. I am taking boat on the water tomorrow (Sunday) for some engine adjusting, will se how temperature will hold. I know that I need to buy new seals, but I have no idea what part numbers they are, or where to order them, any suggestions? What the damage to my beer money I can expect? Thank you again for help :)
