Sorry to bring this up again. I've read a bunch of posts about adhesive and want to summarize my understanding. (as I noted in another post, I'm nervous for the next few steps. I can't imagine taking this apart again if I've done something wrong!)
U-joint and exhaust bellows:
1. Use acetone to clean and remove old adhesive from transom side and bell housing. Lightly sand and clean with thinner.
2. Apply adhesive to transom side of bellow (not to the flange) and let it get tacky**
3. Install bellow to transom side and clamp
4. Use Power Tune to help slid bellow onto bell housing**
5. Install retainer ring on u-joint bellow. (clamp for exhaust bellows)
** this is where I couldn't find specific information in manual for the u-joint bellow. For the exhaust bellow it specifically said to apply adhesive to the bellow and only to the transom side. It doesn't say to apply adhesive to the flanges on either the transom side or the bell housing.
I've used contact cement before in other applications and know that more isn't always better. I'm assuming a thin consistent layer will do. Is this the case here as well?
Shfit bellow,
4. Use a zip tie to hold the end of the bellow to the shift cable. snuggle but not so that it can not slide on the cable.
Shfit bellow,
