adjusting carb floats (AQ170A)
MTJames
Ok quick Summary of the motor.....AQ170A..Solex (44PA1) downdraft carbs (trips).
All three carbs rebuilt and all orifices cleaned/blown out. Just need to adjust the floats on the carbs to allow more fuel in the bowl. The fuel is low in the bowl, but can't for the life of me remember which way to adjust the float to add more fuel in the bowl. A very simple float, brass tab with a single screw going through it. Adjustment is float up or float down by bending the brass tab up or down. But again, I can't remember if bending the tab up it would add more fuel or bending the tab down would add more fuel.
BTW fuel pressure is good.
I thought i had a picture of the carb, but I guess not
