um0RION
- Joined
- Aug 28, 2009
- 88
First off, ive got a 120hp evinrude VRO motor from 1991, E120TLEIE. I hate that im posting this and being so pressed for time, but Im having some bad problems that need attention before I take my boat out of the area (tomorrow).
Ive got idle problems.. When I speed up, then slow back down, the rpm does not go all the way back down to idle. My mechanic says the throttle cable needs tightening, and I agree. Tightening it would push the throttle further down towards idle.
Here's the issue with that: There's a thumb wheel on the cable that you're supposed to turn, but mine will turn about 3/4 of a turn, then stop dead. There's a clamp holding the cable to the engine block, do I need to undo this before I tighten the cable?
Also, I disconnected the throttle cable, and with it dangling, moved the throttle back as far as it would go, and while it wasnt running, it was in the same position it was in when the cable was hooked up with me pushing the throttle arm to idle. As it was, this seemed WAY too high for an idle speed. It had to be over 1000 rpm. I know it wasnt in water, but it seemed way too high. Is there some other adjustment that lets me idle it further?
This problem seems to be a bit out of my league. Any help? Or is this something I should bring to the mechanic, and NOT take my boat 4 hours away this weekend
Once it goes, its staying there until fall, so...
