ADJUSTING THE HIEGHT
russeller
I SEE A LOT OF PEOPLE TALKING ABOUT ADJUSTING THE HIEGHT OF THE MOTOR HOW LOW OR HIGHT SHOULD THAT BE HOW WOULD YOU KNOW TO ADJUST IT?
ob
Re: ADJUSTING THE HIEGHT
Outboards will run best placed as high as possible without causing loss of prop bite and waterpump intake issues.This minimizes exhaust back pressure (if your engine has thru hub exhaust) and also decreases drag.The usual procedure is to raise the engine in small increments and water test for results .
russeller
SO IF I MOVE IT UP IT WILL RUN BETTER ? I HAVE A 66 RUDE 40 ON A 67 GLASTRON FIBERGLASS
ob
That's not what I meant.I don't know what handling characteristics your boat and motor have now at its present setting.The rule is to get it as high as possible without having prop ventilation(coming up on plane and executing tight turns on plane) or waterpump pressure problems due to it being mounted too high.There is a sweet spot.For me to recommend that you simply raise it without my knowing the specifics of your present setup would be irresponsible on my part.
NathanY
As a general rule, the anti-cavitation plate needs to be at about the same level as the bottom of the boat.
russeller
THANKS IF THAT IS TRUE MINE IS WAY AND I MEAN WAY BELOW THAT WOULD THAT SLOW ME DONE IF IT IS THAT LOW ?
NathanY
Yes it would, it puts ALOT of drag in the water.
russeller
THANK YOU FOR YOUR HELP ON THIS MATTER I AM LEARING ALOT FROM THIS SITE
