SeaRay Weekender
- Joined
- Apr 25, 2008
- 18
Guys, I have a 1986 Mercruiser Alpha 1 Sterndrive I'm trying to adjust the trim limit switch on. It was working perfectly until I struck a submerged object. Prior to this, the trim went up until the red line as indicated on the trim gauge, further then that the Trailer button was needed and worked. Now the outdrive only goes up about halfway to the red line on the gauge, if I want it any higher I need to use the trailer button. So I tried adjusting the limit switch on the port side of the gimbal housing and was able to get it to go a little higher, but still not to the red line on the gauge like it used to. The limit switch is now adjusted out to the end of its adjustment range. Can I take the switch completely off and reclock it to get where I need to go in the adjustment range?
