saltydogjeff
- Joined
- May 12, 2013
- 145
I will know more tomorrow. Not really experienced in this area. I opened up the valve cover the other day to take a look at valve adjustment because I was told my compression was off on a compression test on the first cylinder. I personally don't remember what the compression numbers were. I think the compression in the first cylinder was high compared to the other cylinders.
So, I got a compression tester to test the engine compression tomorrow. If I need to do some valve adjustment, how do I adjust these valves? I got my wrench on the rocker arm bolt, but there was no play in it what so ever. I saw some YouTube videos that had an allen wrench location for setting the rocker arm, but nothing of the sort here.
I don't see anywhere else to make an adjustment.
