Advantage of gen II over gen I - Mercury w/ Alpha Drive
neuro242
Didnt find what I was looking for using search. Im looking at used boats, both '90 and '92-94 models with Mercury sterndrives. Am I right to say the '90 is Gen I and the 92 and through 99 or so is Gen II? Im wondering if there is a big enough advantage in the Gen II to keep me from a good deal on a 90 model?
ziggy
Re: Advantage of gen II over gen I - Mercury w/ Alpha Drive
this may help
Quote: Originally Posted by JustJason
I scanned these from my notes and converted them into pdf's... So a page may be tilted here and there, but the quality is good.
1. What is the history behind my Mercruiser Alpha drive?
http://www.4shared.com/file/11352017...e_history.html
it's from the adults only sticky at the top of the i/o page. #10 i think
Alpheus
Gen II started in 1991. In the Adults only section under Miscellaneous Mercruiser information You can download the article labeled How to ID an Alpha Style Outdrive, and History. This will tell you all the differences between the different outdrives...
here is the link to it...
http://www.4shared.com/file/21385430...nd_Histor.html
Don S
To answer your questions, they are both good drives, and each has high and low points. I wouldn't discount a 90 model because of drive alone.
One note, I moved this thread from the Mercury Outboard forum, and I see that you call it a Mercury Sterndrive, which it is not. It's a Mercruiser, which is the sterndrive division of Mercury Marine.
Mercury is outboard, and Mercruiser is sterndrive.
neuro242
Thanks. I just learned about 20 new things this morning thanks to this board and the good ppl using it. Thanks again.
havasuboatman
Ensign
One more thing you learned. Mercruiser made the
Alpha 1 and the Alpha 1 Gen 2. There is no Gen 1.
Ayuh,... Their Very comparable drives,... Just Not compatable....;)
Alpheus
Its a Gen I.
John Doe "Senior" wasn't given that name at birth, it was changed when John Doe "Jr" came along... ;)
zbnutcase
One of the biggest improvements on the Gen 2 is water pump. 'nutcase
