advice for winterization in NJ
skysurfer2010
I found a listing online from a company that will come to you to winterize your boat. His prices seem in line with other marinas I've checked out, but I can't find any reviews online about the company:
http://www.octopusyachts.com/winterizing.html?gclid=CMfX1cyD7Z0CFc5L5QodWBo-LQ
I consider myself somewhat mechanically inclined. I previously owned jet skis and am comfortable working on them and winterizing them. I've never worked on a boat or car before and all the steps look a little daunting to me. Ideally I'd like to learn how to winterize my own boat and by having this company come to me I'd be able to possibly help out/ assist with the winterization.
Should I take the risk and have someone I know nothing about winterize my boat? Or should I just let a trusted marina do it? My only issue with letting the marina do it is that I won't be learning anything from it.
If I call this company, what questions should I be asking them?
Thanks for any advice and sorry if my questions are bad.
blouderback
Re: advice for winterization in NJ
Winterization is pretty easy. The most important thing is to get all the water out of the engine. Pull all the drain plugs (mine has 5), and then stick a stiff wire in the hole to make sure there's no debris clogging it up. Some people fill it with anti-freeze, some don't.
Next most important is to change the fluids (motor oil and outdrive lube). You don't want dirty oil and/or lube sitting in there for 5-6 months. If there is any trace bit of moisture or contamanent, it can create a rusty situation.
Fog the engine to coat the cylinders and carb (or injectors) with a light coating of fogging oil. This inhibite varnishing, which can make it hard to start in the spring.
Then, make sure your fuel is stabalized. I have forgotten this in the past, and it hasn't been a problem, but Stabil in the tank is cheap insurance.
Lastly, give 'er a nice wash and wax, and tuck her away under a nice tarp or have 'er shrink wrapped. I use a tarp I got at home depot for about $30, and it's lasted 4 seasons so far.
ErieRon
If you follow the link below, and have the complete model numbers from your engine and drive, you can download the factory manuals for free (from the Adults Only thread);
http://forums.iboats.com/showthread.php?p=2360521#post2360521
Give them a quick perusal, then decide. Winterizing is not difficult, it's all in what you are comfortable with mechanically, how well you can follow instructions, and thoroughness.
A certified marina will do a fine job I'm sure, and they stand behind their work. The "dockside or driveway" guys...I don't really know. I wouldn't expect them to let you help and teach you though...job security :D
