Hey guys, looking at a new to me boat, but i need some questions answered before I think about buying it. From what i know, and this might not be exactly accurate, its a 79 sunray fiberglass hull- 18ft with, and this i know, a model 400 3.0l OMC engine. heres the thing- i'm told it will run all day long at full rpm with no issues,7200rpm is what he tells me- the problem is when you put it into gear, where it will bog down and lose all spark/power. He's been told it's the 2 microswitches involved with the shift linkage thats at the rear of the motor- theres a pic of an engine on this site where these can be seen when the engine is googled, but when actually on the site- pic doesnt load- anyways- aluminum looking piece mounted behind the engine that has the shifter cable attached to it. theres 2 microswitches there that interact with the shift linkage. from what i'm told- these are killing the spark when being shifted into gear. does that sound right? can anyone with experience in this area weigh in? the history of the boat is that it ran great but with a small valve tick for 2 or 3 summers- owner bought a reconditioned head and put it on, set timing, and had carbs cleaned over the winter- when started up- the tick was gone and you could apparently barely hear it running, but thats when this happened, as i said- runs perfect until shifted into gear. ideas and thoughts please,
thanks
Matt
thanks
Matt
