snowman4evr2012
- Joined
- Aug 6, 2018
- 8
Hi, so we just got this 1988 boat, and supposedly it just needed a head gasket but while troubleshooting it after pulling intake we found the block cracked in the lifter valley. Its a solid boat with fiberglass floors and is in what i would consider fairly good shape. Engine is showing 1200 hours. So just acquired a running 1989 tbi 4.3 out of a van. We plan on swapping everything over from the omc to this engine after we freshen it up a bit. Just wanted to see if we could get some advice from an expert, as we are not. Iam an electrician not a boat mechanic! Anyway here's what were thinking, and the many questions I have on this endeavor. We aint got a whole lot of money to invest in this as it was unexpected to say the least.
Have old omc heads rebuilt-- By rebuilt i mean by a professional not myself. Iam thinking new valve stem seals / 3angle valve job? anything else?
Any ideas on the best rebuild kit / gaskets we should use?
Should the pistons / cam be replaced, or swaped over from the omc to the van motor?
New timing chain
I want new lifters
was thinking about swapping out the factory freeze plugs for brass, but is this necessary for freshwater use only?
Of course was gonna give it new cap,rotor, points, plugs, wires, etc..
New timing chain
I want new lifters
