Re: advice on buying old fiberform
Thanks for the info! i have no idea if they sold it yet or not. We ended up buying a small 14' fishing boat for now, which we have had to struggle with registration issues and havent got to use yet, and my dad was going to give me his old 70's starcraft holiday (19' I beleive). I'd realyl like a bigger boat, but that will have to wait a few years.
The boat pictured has what appears to be an OMC outdrive. Considered by many to be an inferior drive. The bell housing/intermediate/outdrive are all bolted directly to the engine and trim is achieved by raising and lowering the front of the engine. It all goes through a large rubber boot on the stern. These drives DO have some inherent flaws...mainly the tilt mechanism and the coupling system which is not a U joint...BUT, they are built very tough. Honestly, my favorite drive is Volvo Penta, but I would not dismiss a boat I really liked due to an OMC drive. Contrary to what you might hear, you CAN still get parts for the OMC drive. I completely rebuilt a 800 series drive with no problem.
I dont really know anything about out drives, but my dad has told me to avoid volvo's like the plague. One of his friends I guess has had to rebuild his twice and cost thousands each time. I dont know much about em but I know I cant afford to spends thousands thats for sure! I think the starcraft he is giving me has a mercruiser, but again I dont know anything about them yet.
This is referred to as a "stringer" drive because the engine is mounted to two longitudinal stringer fiberglassed into the hull and the forward thrust of the outdrive is transmitted to these stringers rather than the transom of the boat...not a bad thing, but the stringers need to be solid and on some of the older hulls, these stringers have dry rot or just plain rot. You need to check that out. Here again, they can be replaced but it's a lot of work.
Hmmm, are these stringers visible for inspection?
Overall...these old fiberforms were great seaworthy hulls. I currently own a 22' Baja flattop sedan that I am using and rebuilding. I love it, but you need to love working on boats. If you don't, spend a little more and get a newer hull. Bayliners are fine and you get a lot of bang for your buck.
Thats pretty much what all my research has revieled... they are great heavy duty boats. But I suppose anything as old as the 70's no matter how good in initial quality is probably going to need some serious rebuilding. I dont mind having projects and doing stuff mysels, and soon to build a nice size pole barn. But I just dont have any experience with boats yet, I'm a quick learner but I dont know if a big older boat is too big of a project for something I know little of and dont have any friends into boating either.
But I have made my first step towards owning a big boat
... just bought me a new truck. My half ton was only rated at 3200# towing capacity which even that fiber form would be well over that I would think. New truck is 6500 conventional hitch / 12.5k weight distrubuting hitch so think I'll be set. just got to decide if a bigger boat or camper trailer is nearer in the future!
