Re: Advice on new to me 1993 SPX Please
alright bud, that black "coupler" is called the bearing carrier assy. With ski NOT in water, that unit will get hot, since the lake keeps it cool. Inside the carrier assy, theres the seals to keep water from entering the hull. The "flywheel" is actually called the PTO. its "splined" so the driveshaft enters it.
The bearing carrier assy, SHOULD NOT rotate wit hmotor going. If so, you just now stripped the thru-hull fitting, which then now, needs to removed and a new one inserted using resin to re-seal to hull. Have to remove the pump assy to perform fix.
There's 2-zerk fittings that need to be hit, every other ride. One on the carrier assy and one on the pto..(under the grey cover, covering the pto). If the carrier assy didnt spin, but getting hot and/or allowing water (when on lake), to enter hull, you'll need to order a new assy..(no big deal).
With ski that old/not started, you'll want to remove the carb/s. Problem is, the carb/s are held together to intale manifold via studs coming up from manifold, where as, newer seadoos (95-on), theres allen bolts going thru the carbs to manifold.
You'll have to remove the intake, which takes undoing air assy and fuel inlet, return and pulse hose, from carb/s. Next, theres 4-13mm bolts holding manifold to case. 3 are easy to get to, but the 4th is tough. Front (mag side) at bottom. Can get to, but takes abit. Once bolts removed, hold manifold in place and use a skinny flathead to, once start removing manifold SLOWLY, use screwdriver to "push-back" rotory valve in place on rv assy..(a gear that protrudes from case). Doing so, you wont lose the "timing" of motor in relevance to valve.
With all good to this point, now remove carb from manifold. Go thru carb. You'll see the inside filter all plugged up with blue/green slime, from the fuel lines. Once gone thru, you'll probably ONLY have to replace the diaphram..(black circular pumper), since its probalby all dried out.
With you ready to re-install carb to manifold and manifold to motor, once alls put together, go to oreilly/advance..etc, and get 30r7 regular fuel line, and replace all the grey crappy lines. Only grey line you dont need to replace is the "vent" line, off the tank.
Make sure when installing new fuel lines, to go thru the fuel selector switch..(on/off/reserve) switch, because that green/blue slime, will be in there also. Also, replace/remove the inline cannister filter because that has an oring, which goes bad and will pull air from it...not good.
The pump assy, if bad when you remove from hull, if the bearings are bad, your better off getting a good/used pump from ebay or hit me up. I got a bunch of them....good luck.
