Advice on Temporary Pressure Relief Valve Removal
Muddyjeep810
Hi again guys. So I have my head and exhaust manifold off my 1977 70 HP Johnson. The powerhead had previously suffered an overheat and it melted the pressure relief valves. I found pieces of them throughout the water jackets.
The thermostat works as it should. I put it in a pot of water on the stove and reading the water temp with my cooking thermometer it started to open right around 143. I cleaned it up some and I plan on reusing it temporarily.
Anyway, I am heading up north on vacation early next week and I planned on taking the boat with me. I cannot get new pressure relief valves in time for the trip. Will it be ok if I temporarily run it without the pressure relief valves in?
From what I have read, this will lead to the motor running cooler which shouldn't cause any damage correct? Also, will this have essentially the same effect as removing the thermostat?
I do plan to order the parts, as well as a new thermostat, I just don't want to do any damage to my engine. It's an easy swap once they come in.
Thanks in advance.
Faztbullet
Actually it could cause overheating as water will flows thru to quick at slow speed
