bryanredfish
- Joined
- Apr 22, 2002
- 182
If I understand it correctly, I am to place the water separator between the tank and the bulb. If this is the case, I have only one option: place the filter apparatus in the bilge, which the gas line passes through. It won't be under water (I rarely get any water in there), and if any water gets in, the filter would be well above. Only electronics would be the bilge and aerator pump. I can't see that I have any other options -- there's just no place else to put it!<br /><br />Do you guys see that this is a problem? Access is as simple as a 8-inch access port. No problem checking/changing the filter. Thanks for your help!
