Advice really needed Quick pls 93 OMC 7.4 vs Merc 7.4
asgrinne
93 OMC 7.4 vs Merc 7.4<br />Ok husband is a GM die hard. Penta vs Merc in the early 90'S. <br />Good bad ---same--- Really have no experience with those matches. Looking at a boat today. :p
phatmanmike
Re: Advice really needed Quick pls 93 OMC 7.4 vs Merc 7.4
what are you asking? calm down and try again.<br /><br />both 7.4's are gm motors. one is assembled by OMC and one is assembled by mercuiser. 454 cubic inches of gas guzzling fun. yeee haw
asgrinne
Really just wondering if anybody has had experienced both of them to compare.. Realiablity Repair type information. Sorry very excited.. <br /><br />Think its actually 460 king but have not determined the outdrive yet. <br />Does this splain it a little more. Husband is just die hard GM guy and is leary of the OMC
Dhadley
A 460 King Cobra is a Ford.
lakelivin
If your question has to do with comparing the OMC with the Merc read the following.<br /><br /> http://www.funkopolis.com:8080/~stuart/cobra/ <br /><br />Above link compiled by Stuart Hastings will give you probably all of the background info on Cobra outdrives you could possibly want. <br /><br />Determine which variety of Cobra the boat you're considering has. According to Stuart the somewhat rare Volvo-style "cone clutch" in the 1993-on "King Cobra" is extremely durable, and it is not subject to the "bad gears" failure the others have a reputation for. He says if you have one, buy the manuals, and take it to a qualified Volvo technician. Rejoice! Volvo-style gears are renouned for near-indestructibility. <br /><br />Other King Cobras have a dog clutch, which has developed a bad rep in some circles. Much of this appears to be a result of work done by mechanics inexperienced with Cobra outdrives rather than deficiencies in the drive itself. So if the boat you're considering has a dog clutch cobra, read Stuarts article pretty thoroughly. <br /><br />A key issue is the relative scarcity of technicians with OMC expertise as compared to Merc. Unless you are planning on doing all needed outdrive work on the Cobra yourself, I suggest you make sure you've got a mechanic at a local repair shop with real Cobra expertise before you make the decision to buy one.<br /><br />By the way, I've got an 1989 4.3L Cobra. Never had a problem with it till a local shop left it about 40% low when they changed the drive oil last summer and the gears and bearings got trashed. From now on, for anything I don't do myself I'll be making the 1.5 hour drive to a trustworthy Cobra repair shop a couple of towns over.<br /><br />Lastly, I bet by the time this is posted others will have already pointed out that the way the boat has been maintained is more important than than most of the differences between similar makes & models.
Boatin Bob
Need the year but to clarify the 460 King Cobra in 1989 was a dog clutch, in 1990 they switched to the cone clutch style and in 1991 you could only get the 7.4, the 7.5 (460) was no longer available. If it is the cone clutch then Stuart's site above isn't much help. The OMC's were/are fine if they were properly maintained and if you can find a good OMC mechanic for repairs.
asgrinne
Wow I love this place.. Yup have to see the specs on it. Thanks ever so much. <br />Tried to find it in the dark last night and got lost. So that is todays project.
