My 1977 75hp Evinrude was running rough. It would die unexpectedly after running good. A few month ago I did a compression test and found all the clyinders around 110. Saturday I did a compression test and got 110 on the top cylinder, 110 on the 3rd cylinder and nothing (0) on the 2nd. I disassembled the engine and found the #2 piston broken on the edge. Enough to see the ring. If any of you guys with older engines have symptoms like these, you probably have a similar problem. Also the lower bearing was missing several ball-bearings. Thanks all you guys who answer our sometimes redundant questions. You've saved me lots of money. BTW, I have to get the head rebored and purchase oversize pistons .040. I've learned how to do it by reading and purchasing a manual. <br />God Bless you.<br /><br />Tech Man
