Aerator pump switch
rglippa
Just bought a 2001 188SD I/O. Great boat, but still learning about the boat. There is a live-well in the bow of the boat, but for the life of me I can't find the switch to turn on the aerator. Can anyone provide me help on how to fill the live-well?
Ernest T
Re: Aerator pump switch
Mine has switches at the helm (SD 217) for pumping and aerating. If your not getting water, be sure the valve is open. Mine has a valve on the inlet line right where it comes through the transom, and another valve on the drain line which is close to the fill line.
NelsonQ
All of the boats have a livewell upfront, however not all are outfitted from the factory with the plumbing and pump to use it. Does it have a drain and a water inlet near the top (on the side)? If not, its simply a storage compartment. My GS170 was this way, my SS188 is setup as a livewell.
Start with checking in the bilge area of your boat. Does it have 2 pumps (one for the bilge and one for the livewell) If it was available, their should be a console LIVEWELL switch at the helm.
Hope this helps
rglippa
Hope this helps
Thank you for your responses. Yes, there is a water inlet at the top and a drain. I haven't noticed a second pump (other than the bilge) so I am guessing that it wasn't outfitted with the plumbing as you say. I will take a closer look for a second pump, but there is definitely no switch at the helm labeled for for the aerator/pump... Thanks again for the help....
