Affordable fuel injection intriguing
matt167
I just ran across Affordable fuel injection for marine engines. I’ve known Affordable fuel injection existed but never paid attention. Shows about $1,500 for a complete kit, which doesn’t use an O2 sensor and a video from 6 years ago suggests they use Mercury marine ECUs with custom software. They actually list one for a 3.0L. I’m not sold on it but it’s actually something to think about.
mercury used GM ECU's same as the GM crate motors of the 90's and 00's
Scott06
Id look closely before laying down the cash. On the hit rod forums you see a lot of quality issues in terms of component of reliability on these systems be it sniper , fitech, etc. not sure if any of the aftermarket system are OEM fuel injection quality like you see in automotive OEM systems, which is the only reason to ditch a carb…
matt167
I think Affordable uses genuine GM TBI throttle bodies and GM sensors.
I wouldn’t hand my cash over without at least a few calls/ emails. I looked a little bit into the Sniper EFI but it always comes down to something isn’t quite right, or there’s a weird surge with the shift interruption or the O2 sensors reading incorrectly and not learning a good tune.
I’m not 100% sold on EFI but I do like my little boats DF25A. Wait for the beep and turn the key
matt167
I got an answer back from them. They install an automotive module in the Delco EST distributor, which is actually for TBI trucks. Makes it so the ECU can control timing. He said the shift interruption will still work and he said that installed correctly it will pass a USCG inspection. He didn’t specifically say if the TBI was coast guard approved, but I think it is. All in all I think it’s probably a good kit, being that it uses all OEM GM/ Mercury marine components.
I just have to decide if instant start without waiting for a choke is worth it. My engine now has a Chinese carb on it and while it works, the accelerator pump seems to not work and it’s got a stumble. I didn’t toy with it much since I smoked the impeller when I got it running. So it’s either EFI or get a professional rebuild on my original carburetor.
dingbat
Neither GM or Mercury make embedded processor modules (ECM)
My main concern would be long term support for the ECM
Scott06
Find the GM part number for the TBI module and get a used one off ebay.
That's what I did with my TBV module put a saved search in and when I saw one for $180 I bought a spare
Flag on the play
This means it's not USCG certified, only that if inspected it should pass because there is nothing obvious
Look into Holley, they are CG cert
matt167
Flag on the play
This is kind of my thinking. I know that they use rebuilt OEM GM TBI throttle bodies, so it would come down to IF GM/ Rochester actually ever certified the TBI model they use for coast guard compliance, but I knew he was doing a marketing ‘dance around the question ‘
As for the Holley, that was my first thought but when you read reviews for marine installs, the wedge plate for the O2 sensor sometimes causes funny readings, mercruiser shift interrupters sometimes cause a weird stumble and a few other things. That was the appeal to Affordable since it didn’t use an O2 sensor and also the ECU can control the timing. There is no distributor that will work with the Holley to control timing in a marine environment since it needs the module bypassed leaving a hole
matt167
The TBI modules are like $50 at a parts store
Not so sure along those lines, been a few building big motors on OSO that have had good luck with Holley Sniper
EDIT: Wait, holley doesn't make the ignition. You use what ever ignition you want and build the fuel tables to match what is needed
Holley and MSD are now under the same umbrella
Scott06
Wonder if mercruiser used the same TBI for their EFI engines ? If so then they would be marine approved
matt167
Holley sells distributors made for the Sniper that are adjustable and can be phased for the sniper so that the sniper can control the timing.. I have a 3.0L so no such distributor available. The Delco EST will do the trick if it’s tinkered with and the module bypassed. It is basically a TBI distributor, so the information is out there. Just not sure what I would plug the hole for the module with, since that’s a big. Issue on a boat
The sniper will run fuel only with even a points distributor so I do always have that option
matt167
Pictures of them online show Rochester products but some of them also have a Mercruiser emblem cast into the base. Since fundamentally they are identical, it would wonder if a little detail like that mattered that much
