afraid to over tighten the mounting collar
rickiefs
i had a few posts before sayin i had water coming<br />in by the bilge. well i found it .the mounting<br />collar. the top is flat against the transom. but the bottom is around an 1/8 inch away. someone before me that owned the boat put silicon on it.<br />my question is iam afraid to tighten dowm the bottom bolts because the wood by the nut inside <br />the boat looks a little rotten,can i put a plate <br />behind the bolt ,and then tighten it up so its flat against the transom. or will a good grade silicon seal it so i can take a few more trips out on the lake to fish with my son.then for the winter i can replace the o ring. it does not look in bad shape at all. \ :confused:
flashback
Re: afraid to over tighten the mounting collar
do a search on rotten transom, the only thing you can do is replace the transom, otherwise the engine and outdrive will eventually tear loose and rip the back end out of the boat...
rickiefs
YOU MEAN I WOULD HAVE TO CUT AWAY THE WHOLE BACK!<br />SOUNDS LIKE A BIG JOB, WHAT DOES THAT INVOLVE
rickiefs
LOOKS LIKE JUST THE BOTTM PART ,A LITTLE ABOVE THE DRAIN PLUG,TO THE LEFT AND RIGHT OF IT UP BY THE TWO BOLTS,THE TOP IS FINE
