Aft cast aluminium corner covering brackets,S/C Chieftan
oceanhorse
Hello Guys,
I was recovering a lost walkway for a friend the other day well the bridle caught the cast aluminium corner bracket and flung it off into the deep.
Does anybody know of a pair of replacement parts? Ideally from a Starcraft but I’ll install anything is better then nothin. Thanks
jbcurt00
The title suggests this is for a SC Chieftain, but pix is of an open utility. If for a Chieftain, the pix is just for reference, they're called transom end caps.
There wont be a star or a handle on the transom end caps for a Chieftain.
That said, your best is to show a pix or your remaining end cap to a metal fab shop locally and get a similar looking cap welded up out of flat stock.
They occasionally pop up on ebay for any 1 of several similar looking boats, but not very often and regularly not for SCs.
Rumor posted to facebook over a year ago, was that an SC dealer would sell you a new 1. But when pushed to prove the purchase and provide contact info for that dealer, so others could buy them too, I was blocked. And no end cap was ever posted to that thread, so, might be possible, might not.
You could try a dealer and then report back the results.
Try searching for Transom End Caps
there is a few sets of end caps on fleabay right now without the handle for $99
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
+1 for custom fab
I had to have both mine, the transom cap, and the nose cap custom fabricated. Couldn't find replacements
SHSU
oceanhorse
Thanks you very much guys,JBcurt00 you’re correct. I appreciate all of your advice guys. I’ll look into Fab a pair vs fleabay.
