Re: After Market Outboard Brackets
Probably pretty tricky to make a good patch as the transom will flex and will tend to crack the patch unless it is just as stong as the transom.<br /><br />By using a bracket you are adding a lot of leverage stress to the transom, and may still have to re-inforce it anyway.<br /><br />Lastly, one advantage of the transom cut-out is it will let the water ESCAPE, whereas with a full transom, if you do get a big enough wave, you will be carrying it around for awhile! Also it is going to be a lot of work, and may include new steering cable, control cables, etc. since your motor will probably be 20" further away. And if not done in a professional manner, will De-value the the whole rig.<br /><br />I am not familiar with this particular boat, are you saying that the deck is even with the bottom of the cut-out? Or is their a fiberglass well surrounding the cut-out area?<br /><br />Good Luck, Mike
