After oil injection removal
James P
Is there a need for any carburetor or other adjustments?
Also, does the plug to fill the space of the driven gear need to be gasketed or siliconed where the two bolts go in? Thanks in advance
Faztbullet
Re: After oil injection removal
If your using the factory block off stem style plug it has a o-ring on it about 1/2 inch down and that seals it. If you using a homemade or aftermarket use a gasket and use a dab of sealer on screws..
James P
Thanks Faxt. I am using the factory block off and it has an o ring. You've saved me some time, trouble and a little money!
