After reading the sticky about searches...
BobnAbout
I try to search on 4 hp, 2 stroke and all the posts the use 4 or hp or 2 or stroke appear. How do I get a specific search with all the search terms? I want info on a 2003 Mercury 4 horsepower - 2 stroke motor that
i am thinking on buying and need info on revival. And yes I read the generic motor revival post.
Silvertip
Re: After reading the sticky about searches...
Reviving any two stroke is basically the same regardless how small or large it is. The engine needs fresh fuel, good spark, and timing must be correct. Start it up. Change lower unit lub and impeller if you have no idea when it was done last or as peace of mind.
