After replacing impeller forward gear not ingage
boat 1
Hello, <br /><br /> I have Merc 2002 9.9 HP. After replacing impeller<br /><br />The forward gear not ingage only Throttle works.<br /><br />Reverse gear is working ok. What did i do wrong.<br /><br />Please help. Any info will be appreciated. <br /><br /> Thank you.
PuddleJumper
Re: After replacing impeller forward gear not ingage
No shift after replacing water pump (Mercury)<br /><br />Take the lower-unit back down , put control handle in neutral position.<br /><br />Turn shift shaft on foot counter-clockwise until it seems to stop with fingers......with a pair of pliers; continue turning CCW and it will click over to neutral position, check that the prop shaft spins to be sure it is in neutral.<br />Put foot back on with control and foot in neutral.<br /><br />The old generic Merc and Mariner instructions "remove and replace lower-unit in foward gear" may not work so well on your particular motor.<br />If you need to line up driveshaft when reinstalling foot it helps to have someone turn flywheel so that driveshaft splines line up. Hope this helps.
boat 1
Hello.<br /><br /> I forget to mention that I have a steering wheel, not tiler handle. Also 2 stroke. I wonder if I have a stopper that ties on shift rod a litle bit low. the time that i put on impeller with cover on I turned the drive shaft clock wise to get it in the cover. Does that matter?
PuddleJumper
If it shifted before and doesn't now the problem will only by fixed by dropping lower unit and having both LU and shift shaft in sync
