Aftermarket epoxy coil that works so far
WinnerCougar74
It's always good to find aftermarket parts since originals are hard to find and expensive.
I got this epoxy filled coil on ebay for $23.75. The title said "Blaster Ignition Blaster SS Coil High Voltage -40,000V Male E-Core Square Epoxy" So far it is working just fine. I bought 2 just in case. It should be an easy swap if it fails. You just have to drill out the one hole so the screw will fit. My motor is a 1974 135hp. You also have to put a new end on the coil secondary wire. I replaced all the wires so it was no problem.
tg3690
Yeah, the CDI replacement is $99 for mine (182-5475)......good to have other options available, that work. (y)
ryan 98
These old ignition systems are pretty forgiving when it comes to swaping stuff like coils. That's one of the reasons I like em. I had an old 100hp johnson at one point that was running a completely home made ignition with a car coil. Who ever did it got it to work reall nice aside from it eating points pretty quick
