age and advise on johnson 25hp
lscottyj
given a boat with johnson 25hp J25TELEDA. Can you tell me age and any other tips I should know. Getting ready to see if it starts. As you can see by the cadet ranking I am new to boating. thanks
lscottyj
Re: age and advise on johnson 25hp
Thanks for the quick reply. Am looking forward to this forum to help educate me on boats and hopefully prevent some mistakes I would have made.
Vic.S
TE = tiller, electric start
L= longshaft (20")
ED = 1996
Check, clean, reset or replace plugs
Check compression if you have tester or if any trouble
Check spark
Check/top up gear lube. Suspect seals if any signs of water (milkiness)
Pump impeller maybe if not known when last changed.
Give it a try in a tub and check water flow
Take it out for a spin check for overheating
Read http://forums.iboats.com/showthread.php?t=158086
