Re: Air Breathers Pumping Oil
I'm just frustrated of the running around with this engine... When the mechanic did the compression test he gave me the compression numbers which I posted. He also said the leak down test was normal. I'm going to do my own leak down test tomorrow.<br />They thought about the high lift cam when they built the risers. The water exits are way down the exhaust.<br />
<br />
<br />These are some pictures of the rocker cover air breather holes. I don't know if this will cause oil to come through the breather hole<br />
<br />
<br />
<br />
<br />These are the breather caps. One has the sponges eaten away inside by having gas flowing through it.<br />
<br />The cap doesn't seal to the rocker cover because of these rubber seals.<br />
<br />Thanks guys
